STM32F4 SPI SD Card Problem
emsing007
Posted on October 11, 2014 at 16:15
Hello!
I use STM32F4 Discovery and SD Card (library ChaN: https://github.com/devthrash/STM32F4-workarea/tree/master/Project/FatFS).
I complied program from example (main.c in Project) and SD card not work.
In debug mode program stop on 228 line in file diskio.c
228: (SPI_receive(SPI1, buf, 2); // receive two byte CRC
Connection:
CS -> PC4
SDI (MOSI) -> PA7
SDO (MISO) -> PA6
CLK -> PA5
#sdcard-spi
Posted on October 11, 2014 at 16:38
Sounds like you're going to need to break out a debugger and scope out and start to understand what's going on, what the code you're using does, and how it interacts with the circuit/card you've interfaced.
