stm32f4 hardfault
jhasa.2
hi
I use stm32f4 micro but an external interrupt pin
when i increase frequency of the external signal connected to interrupt pin, the micro jump to hardfault
why? how I can detect the solution?
35 REPLIES 35
SRedd.5
Senior III
At what frequency of the external signal it goes to hardware fault? Below this frequency which function you are calling when interrupt happens?
the interrupt routine is free and i commented all the code in it.
the frequency above 3khz will be Hard Fault.
how i can see the problem detail in hard fault?
The sequence is step1: HAL_GPIO_EXTI_IRQHandler function is called and after that some issue happened and the hardfault handler is called. Can you show your code? In the interrupt handler can you toggle a port based on the external input signal, so both shall match for debugging purpose.
I attached my code.
Maybe something in get_sample() is causing an issue?
Have you tried commenting out adc_read_value[adc_read_index]=get_sample(); to see if it still goes to hardfault?
If smoke escapes your device, put the smoke back in. It'll still work as a conversation piece. If you find my answers useful, click the Accept as Solution button so that way others can see the solution.
i remove all of the interrupt routine but it crashes.
only when i remove external interrupt it will be ok
why?
>>why?
These things don't need to be guessing games. Go identify what's actually faulting and work backward from there.
If you don't service interrupts in handlers, they'll keep entering.
Have a Hard Fault Handler that does something more useful that while(1), I've posted examples on multiple occasions on.
https://github.com/cturvey/RandomNinjaChef/blob/main/KeilHardFault.c
this data is displayed on stm32cubeide
what i should with this data?
What data?
