2013-04-14 1:20 AM
Hello everybody,
Where can I find the documentation (user manual) for the STM32F407VG core from the discovery board ? The doc needs to have all the registers for the core and peripherals :) a NORMAL user manual...Thanks a lot !Regards,Mihai P #lmgtfy:-stm32-resources2013-04-14 5:38 AM
2013-04-14 6:03 AM
ST has four basic manuals
A Data Sheet/Manual for a specific part with pin designations (STM32F407VG). A Reference Manual for a family of parts (F4), RM0090, with peripheral registers A Programming Manual for the flash memory. A Programming Manual for the Cortex-M4, this describes the core, you could also pull the ARM TRM Let's say we Google ''STM32F407VG'' First hithttp://www.st.com/web/catalog/mmc/FM141/SC1169/SS1577/LN11/PF252140
The data sheet is listed herehttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00037051.pdf
Go to the ''Design Resources'' tab At the top is the Data Sheet again Scroll down further for Reference Manual Programming Manual
