2015-11-24 9:23 PM
Hi everyone,
I just want to seek your guidance and help in accessing 12 signed 32 bit integers, which are calculated by using STM32F4 Discovery board, in my PC, through USB.I read many codes/post on different forum and could not figure out from where to start. I am very much beginner with this board so need your help. These variables are constantly changing and I wish to access in real time. Can anyone help me in locating suitable example so that I can start.2015-11-25 7:20 AM
Hi w.a,
I advise you to refer tohttp://www.st.com/web/en/catalog/tools/PF257920
and itshttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/CD00196932.pdf
. It explains how to exchange data using the HID class protocols.Also, you can have a look to the example under STM32Cube_FW_F4_V1.9.0\Projects\STM324x9I_EVAL\Applications\USB_Device\CustomHID_Standalone.-Shahrzad-2015-11-25 2:24 PM
2015-11-25 6:40 PM
2016-01-31 7:32 PM
I need your kind help in searching out some solution for sending data as output on STM32 pins and accessing it from the computer.
a). I have 9 variables (16 bits), calculated in MCU and want to send them to output pins of STM32 board (can you please share any example similar to this??)
b). Access them on computer by any mean (USB or serial port)
Please note that I just want to put some values on some pins of STM32 discovery board which can be read by the computer at any time. These values may be updated frequently but some check should be there that when computer is reading those values they should not be updated.
Your help in this regard will be highly appreciated.
