2014-02-17 12:51 PM
1- When using MATLAB-Target to configure stm32f4 discover board , some problems arise While building the stm32d demos. for example while building the code for ''ButtonAndLeds'' demo, the following error occurs :
''♯♯♯ BUILD_MODE real_time''
Error: L6218E: Undefined symbol profileTimerInit (referred from main.o).
Error: L6218E: Undefined symbol xilInit (referred from main.o).
Error: L6218E: Undefined symbol xilRun (referred from main.o).
Finished: 0 information, 0 warning and 3 error messages.
gmake: * [ButtonAndLeds.axf] Error 1
♯♯♯ Real-Time Workshop build procedure for method: 'error
♯♯♯ Real-Time Workshop build procedure for model: 'ButtonAndLeds' aborted due to an error.
some other errors occurs while building other demos. I think that all of them are related to *.o files in some way.
2- How can config the MEMS? I did't see any block relating to the MEMS
any Idea?
#stm32f4-discovery-board---mattar2014-02-19 04:06 AM
regarding MEMs, there is no model. Did you have a look on Readme.html file? Did you verify your model parameter settings? It seems your main file is not generated correctly. Regards Pascal
