STM32F4-Discovery Audio playback and record example USB problem
‎2012-04-20 7:43 AM
I am beginner with STM32F4-Discovery. I loaded some examples to flash, all worked, but can't play ''audio.wav'' wave audio file from USB key nor record ''rec.wav'' with ''audio player and recorder example''. Program goes over USBH_Process(&USB_OTG_Core, &USB_Host) in main.c, and cycles here forever, no blue led ligths up, no sound, no switch to recording mode. It seems like something wrong with usb flash connection initialization, because USBH_Process function in usbh_core.c repeats at ''volatile USBH_Status status = USBH_FAIL'' after ''case HOST_ERROR_STATE:''. How I can fix this, or what I did wrong?- Mark as New
‎2014-08-22 1:46 AM
I am also facing the problem, Anybody please come up with a solution.- Mark as New
‎2014-08-22 2:11 AM
Is there any version of FW for ECLIPSE IDE??
Atollic is Eclipse-based, so it is as close as you can get. However, you need to come to grips with your IDE. Of course you need to adapt the project for your environment, because your plain Eclipse is not aware of Atollic-specific settings. Especially set the paths to the sources and header files correctly. If you do not want to use Atollic (or another of the directly supported toolchains) it is best to create a new, matching project from scratch, and import/include all required files manually.
‎2014-08-22 10:36 PM
I tried to build a project using the provided source code in Eclipse IDE.Added all the files related to USB. Now I am stuck with an error ''../src/diskio.c:26:29: error: 'USB_OTG_Core_dev' undeclared (first use in this function)
''. I searched in all the files, but couldnt find a define 'USB_OTG_Core_dev
'. Please let me know what value shall i define for 'USB_OTG_Core_dev'.- Mark as New
‎2014-08-23 3:21 AM
Perhaps you're not supposed to be using that file? Have you looked at the construction of any other of the projects for the supported tool chains? They are in ASCII, and human readable..
Perhaps you should be using STM32F4-Discovery_FW_V1.1.0\Libraries\STM32_USB_HOST_Library\Class\MSC\src\usbh_msc_fatfs.c ? and not diskio.c (a generic form)Up vote any posts that you find helpful, it shows what's working..
‎2014-08-24 2:09 AM
I have created my own project in Eclipse as you suggested.
Compiling the project after adding all the files related to USB ,I got the following error:/src/usb/usb_dcd.c:93:7: error: 'USB_OTG_CORE_HANDLE
' has no member named 'dev
'.I have gone through all the files ,dev
is used in many places (pdev->dev.device_status = USB_OTG_DEFAULT; pdev->dev.device_address = 0;) but it is not declared anywhere.- Mark as New
‎2014-08-24 6:04 AM
Odd then, that the project in Keil, using the correct files, compiles just fine....
Perhaps you should read my previous advice more slowly, instead of dumping all the files you can find into the project?Up vote any posts that you find helpful, it shows what's working..
‎2014-08-24 9:39 PM
Its clear now, I may have added unwanted files!!!
Please let me know the list of header files also.- Mark as New
‎2014-08-25 6:29 AM
This seems to involve a lot of work on my part to do your job. Attached is a dependency tree, in ASCII, parse it with AWK or PERL ________________ Attachments : Audio_playback_and_record_MEDIA_USB_KEY.dep : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzjm&d=%2Fa%2F0X0000000bP2%2F6b.mL8dyasT5bRQv.KkDY1AFN.HPM5O4wdFQsmg16s8&asPdf=falseUp vote any posts that you find helpful, it shows what's working..
‎2014-08-26 12:06 AM
Sir,
Please bear with me if I ask any foolish questions. I have been sitting on this for last two week because this is an important part of my project.As u suggested I have removed all the unused files from my project.Now i m getting an error../src/usb/diskio.c:26:29: error: 'USB_OTG_Core_dev' undeclared (first use in this function).diskio.h
is included inusbh_msc_fatfs.c
. i dont know where is USB_OTG_Core_dev defined- Mark as New
‎2014-08-26 6:53 AM
Stop using DISKIO.C isn't not part of the project, I told you this last week. The functions declared in diskio.H are implemented in another file.
