2016-11-16 01:15 AM
2016-11-30 05:57 AM
I propose that you refer to an I2S example inside the STM32CubeF4 library (v 1.14.0) relevant for your device, and compare the code with the generated one.As the working I2S_Audio example in STM32CubeF4 at this path: STM32Cube_FW_F4_V1.14.0\Projects\STM324xG_EVAL\Examples\I2S\I2S_AudioMaybe this help you to identify what is going wrong in your case.Hope this helps you.Regards
