STM32F4 ADC/DMA always returns same value.
‎2017-04-19 10:16 AM
STM32F437
I want to use ADC3 with DMA to capture values and have them available when needed but I don't need an ISR. Regardless of changing the input the value never changes. Below is the code I am using. Please give a shout if you see something amiss.
Thanks,
JH
#define ADC_NUM_READINGS 1
static uint16_t adc3_result;
static const DMA_InitTypeDef dma2 =
{ DMA_Channel_2, ADC3_BASE + 0x4C, (uint32_t)&adc3_result, DMA_DIR_PeripheralToMemory, ADC_NUM_READINGS, DMA_PeripheralInc_Disable, DMA_MemoryInc_Disable, DMA_PeripheralDataSize_HalfWord, DMA_MemoryDataSize_HalfWord, DMA_Mode_Circular, DMA_Priority_High, DMA_FIFOMode_Enable, DMA_FIFOThreshold_HalfFull, DMA_MemoryBurst_Single, DMA_PeripheralBurst_Single};void adcInit(void)
{ GPIO_InitTypeDef GPIO_InitStruct; ADC_CommonInitTypeDef cInit; ADC_InitTypeDef init;RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
GPIO_StructInit(&GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA, &GPIO_InitStruct);DMA_DeInit(DMA2_Stream0);
DMA_Init(DMA2_Stream0, (DMA_InitTypeDef*)&dma2); DMA_Cmd(DMA2_Stream0, ENABLE);cInit.ADC_Mode = ADC_Mode_Independent;
cInit.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles; cInit.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; cInit.ADC_Prescaler = ADC_Prescaler_Div2; ADC_CommonInit(&cInit);init.ADC_Resolution = ADC_Resolution_12b;
init.ADC_ScanConvMode = DISABLE; init.ADC_ContinuousConvMode = ENABLE; init.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; init.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_TRGO; init.ADC_DataAlign = ADC_DataAlign_Right; init.ADC_NbrOfConversion = 1; ADC_Init(ADC3, &init);ADC_RegularChannelConfig(ADC3, ADC_Channel_6, 1, ADC_SampleTime_15Cycles);
ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE); ADC_DMACmd(ADC3, ENABLE); ADC_Cmd(ADC3, ENABLE); ADC_SoftwareStartConv(ADC3);}uint16_t readVoltage(void)
{ return adc3_result;}- Mark as New
‎2017-04-19 10:59 AM
Try without dma fifo and use an array of 3.elements with incremental memory
By the way for scalability, better write
static uint16_t adc3_result[
ADC_NUM_READINGS];
Adc3_result becomes a pointer... Adjust the code for it.
Otherwise even if the sw is debugged, it would break from 2 samples onward.
‎2017-04-19 12:50 PM
Unless you did it elsewhere, turn on DMA clock - RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);?
‎2017-04-19 1:25 PM
Thanks for posting. I tried these changes but the problem persists.
I changed DMA_FIFOMode to DMA_FIFOMode_Disable and
changed DMA_MemoryInc to DMA_MemoryInc_Enable.
I changed
ADC_NUM_READINGS
back to array and setADC_NUM_READINGS
to 3. I had changed it to a scalar as I was trying to follow the example in the SPL.JH
‎2017-04-19 3:15 PM
Thanks for posting.
Good eye, but my mistake for not showing it. It is done elsewhere, but I just just trying to show the essentials of a much larger project and failed to show that step was accounted for.
JH
‎2017-04-19 11:42 PM
Do you use ADC3_IN6?
On STM32F437xx it is on pin PF8.
Do you use the right pin?
‎2017-04-20 10:44 AM
Thanks John, great catch!
I used the right pin but used the wrong ADC, should have been ADC2_6. This is an update of an old board and all of these type readings were mux'ed into ADC3. So John Boy here gets no points for attention to detail.
ADC2->DR has the right info now but the DMA is not doing what I want. I will start a new whine, um, thread about that.
