2012-10-12 9:49 PM
Input bias current is not listed, so I don't know how to size a resistor divider for use with the STM32F3xx series. Has anybody measured it? Is it hiding in a datasheet I haven't found?
Thanks!-Sasha #opamp2012-10-13 3:22 AM
I have not yet checked this specific item, but it should be in the datasheet.
However, because the STM32F3 is rather new, it is probably unqualified yet. There are hundreds of ''TBD'' items in the datasheet. A rather peculiar strategy of ST to release such sparsely qualified items, IMHO. Edit: The other opamp parameters are given, but no bias current (F302xx/F303xx datasheet, p.109). So it's probably not defined.2013-01-08 2:01 AM
The max value of OPAMP input bias current is available in the last Datasheet. You can check it. Cheers, STOne-32
