stm32f303vct debugger fault
fahadbutt214
Posted on May 07, 2014 at 16:56
stm32f303 debugger is not working
controller
doesnt
 power up with
usb
 connection with
laptop but
when
i
supply external supply of 3v it powers up but debugger still not working
what
could be the fault
#stm32f303vct6 #too-vague
6 REPLIES 6
chen
Posted on May 07, 2014 at 17:02
Hi
Might be one of these :
Bad USB cable
Broken USB port on PC
Bad USB connector on STM32 board
ST-Link on STM32 board damaged.
fahadbutt214
Posted on May 07, 2014 at 17:08
usb
 cable is fine
but
why
doesnt
it powers up
i
 have tried more than one cable
chen
Posted on May 07, 2014 at 17:22
Hi
Add one more to the list:
3/3.3V regulator on STM32 board damaged
fahadbutt214
Posted on May 07, 2014 at 17:41
thanks
!. I powered up controller using external 3v .
how
to fix debugger now as its not working now
chen
Posted on May 08, 2014 at 10:26
Hi
how
to fix debugger now as its not working now  ''
I do not think you have conclusively proved it is the debugger that is at fault.
The ''stm32f303'' is just a STM32F3 embedded processor. I did not find a specific
evaluation board for this part - so I do not know what debugger you are referring to.
Is a ST-Link (in a little white plastic case)
http://www.st.com/web/en/catalog/tools/FM146/CL1984/SC720/SS1450/PF251168?s_searchtype=keyword
Posted on May 08, 2014 at 13:28
Ok, so what boards is this, which USB connection are you using, and what debugger are you talking about?
