2015-11-01 07:06 PM
I am very new to ST microcontrollers and wanted to know if someone can help me with a schematic for the STM32F302R8T6. The hardware I am designing is a USB to CANBUS tool but I need to know whats the minimal circuit needed to run this microcontroller at 72mhz. Below are a few parts I would like to use. See attached schematic. 5v to 3.3v regulator - TCR2EF33,LM(CT crystal - ABS25-32.768KHZ-6-T can transceiver - MCP2551-I/SN Any help would be great Thanks2015-11-09 08:07 AM
Hi Marc,
In order to validate your schematic, I suggest you have a look to the recommendations provided in .-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
