STM32F207 customer HID do not work
duan jze
Posted on May 08, 2018 at 07:31
I'm testing the demo on your website designed by itself.
STM32Cube_FW_F2_V1.7.0\Projects\STM322xG_EVAL\Applications\USB_Device\CustomHID_Standalone,
After the target code is downloaded to the board, the device manager displays as shown in the attachment.
it is mean that
Unknown usb device.
Imen.D
Posted on May 08, 2018 at 11:51
Hello
gaobiao315
Try to disable VBUS sensing inyour USB configuration.
Best Regards,
Imen
Imen
7 REPLIES 7
Imen.D
Hello
gaobiao315
Best Regards,
Imen
Imen
Posted on May 09, 2018 at 03:33
hi,Imen D,
 hpcd.Instance = USB_OTG_FS;
  hpcd.Init.dev_endpoints = 8;
  hpcd.Init.speed = PCD_SPEED_FULL;
  hpcd.Init.ep0_mps = DEP0CTL_MPS_8;
  hpcd.Init.low_power_enable = DISABLE;
  hpcd.Init.phy_itface = PCD_PHY_EMBEDDED;
  hpcd.Init.Sof_enable = 0;
  hpcd.Init.vbus_sensing_enable = DISABLE;
in my usb configuration.
D+ and D- are connected to the chip pin by external resistance?
Posted on May 09, 2018 at 18:40
Hi
gaobiao315
Please have a look to the relatedreference manual and this FAQ, this may help you to manage VBUS sensing:
Best Regards,
Imen
Imen
duan jze
Posted on May 10, 2018 at 10:04
HI,
DAHMEN.IMEN
My problem has been solved
The problem is that peripheral crystal configuration error.
Do you have an example of a STM32F207 chip as a
composite device?
Best Regards,
Duanjze
duan jze
Posted on May 10, 2018 at 10:29
HI,
DAHMEN.IMEN
I want to implement the combination of keyboard and mouse
Best Regards,
duan
duan jze
Posted on May 10, 2018 at 12:03
HI
DAHMEN.IMEN
Thank you very much for your help. The problems have been solved.
Posted on May 10, 2018 at 11:26
Hi
gaobiao315
There is only the available exampleswithin STM32CubeF2 firmware package.
You may get help and find users examples from other threads in the forum that discuss the same subject.
Best Regards,
Imen
Imen
