why my sd card is returning no valid partition is found[fr_no_file_system],sd card initialize is done correctly,using spi for interfacing sd card.
Manjesh R
Posted on May 10, 2018 at 07:47
Imen.D
Posted on May 10, 2018 at 10:19
Hello
manjeshr62
Pleaseavoid to putall the problem description in the title.
It will be better to put a significant title with a description of your issue in the body, this will help you to get more answers for your question.
So, you can edit your post and detailed your issue in the body (board, tools, version of firmware and tools are you using...)
Thanks for your understanding,
Imen.
Imen
