2014-07-07 06:46 AM
I have limited experience with USB. I would like to implement the parallel FIFO interface to a STM32F2. I am a bit at a lost not knowing where to start.. should I use the DMA or something else is more suited to the task?thanx2014-07-07 07:59 AM
What are you actually trying to achieve?
2014-07-08 10:37 AM
talk to a FT245RL chip using a parallel FIFO.
