2015-05-26 01:36 PM
Hi
I cannot find the STM32F10xxx firmware library as described here: http://read.pudn.com/downloads106/sourcecode/embed/437624/stm32/STM32F%20Documents/Application%20Note/STM32F10xxx%20TIM%20application%20examples.pdf
I am searching for the ''TIM example 6'' to run STM32F10xxx TIMx PWM input mode.
Could you please post my the direct link to that file?
Thank you
2015-05-31 10:40 AM
i do not understand them quite well to understand it. could ^you give me a code example?
2015-05-31 04:59 PM
I've posted a lot of examples to the forum, the local search isn't much use, Google generally works more effectively.
Here's an F4 example for USART2, showing the pin configuration, both the pin itself, and the AF (alternate function) mapping to it.[DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Discovery/USART%20example%20code%20for%20Nucleo%20F401RE&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F¤tviews=1016]https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSTM32Discovery%2FUSART%20example%20code%20for%20Nucleo%20F401RE&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F¤tviews=1016
