2010-03-28 02:01 AM
STM32F105 need usb mass storage demo + SDIO
2011-05-17 04:44 AM
Hi Alexander
I search USB example for STM32f105 tooand I don't find sources. What did you find about mass storage ? I need USB host example to load files from mass storage. Can you give me sources you found or say me where you found it ? Thanks2011-05-17 04:44 AM
''I found very good examples of USB mass storage in IAR's example folder but for STM32F103 only''
So what's stopping you just using that on the STM32F105 ??2011-05-17 04:44 AM
I found here:
''C:\Program Files\IAR Systems\Embedded Workbench 5.** Evaluation\ARM\examples\ST\STM32F10x\IAR-STM32F103ZE-SK\MassStorage\''
It is example of USB Mass Storage Device only (for F103 chip).. As I see you need something else2011-05-17 04:44 AM
USB of 105/7 very differ whith 103. Every other modules works fine on 105 exept USB.
I dont have so much knoleges to port USB-MSD code from 103 to 105... maybe someone did it already?
2011-05-17 04:44 AM
I think the best way is that you take spi SD card driver provided by STM32stdFWLib (http://www.st.com/stonline/products/support/micro/files/stm32f10x_stdperiph_lib.zip
, under the folder: STM32F10x_StdPeriph_Lib_V3.2.0\Utilities\STM32_EVAL\Common\stm32_eval_spi_sd.c/h). and you implement it in the Mass Storage demo. Is this the kind of information you are looking for or do you need help in implementing the code ?
