2012-01-10 08:12 AM
Hello
I am designing a new project with stm32f105 ; i need a host usb ; i have checked the development kits i found they use usb_id; but i need to use A-type connector ; so if if i leave usb_id floating ; is there any problem since i will use the usb_library from st ? Regards Sami2012-01-10 09:02 PM
Can you explain a bit more. Which id you are talking about?
And also lemme know which application you want to develop Host_MSC or Host_HID??
