STM32F103C8 SPI1 MOSI ISSIE
MSkor.1
Hi
I try to run SPI 1 on STM32F103C8 but when i send data i have only SCK signal. MOSI(PB5) is in high state (dont change).
 SPI2 on PORTA works grate.
void MX_SPI1_Init(void)
  /* USER CODE BEGIN SPI1_Init 0 */
  /* USER CODE END SPI1_Init 0 */
  /* USER CODE BEGIN SPI1_Init 1 */
  /* USER CODE END SPI1_Init 1 */
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI1_Init 2 */
  LL_GPIO_AF_Remap_SWJ_NOJTAG();
  while((AFIO->MAPR & AFIO_MAPR_SWJ_CFG_JTAGDISABLE) != AFIO_MAPR_SWJ_CFG_JTAGDISABLE);
  /* USER CODE END SPI1_Init 2 */
void HAL_SPI_MspInit(SPI_HandleTypeDef* spiHandle)
  if(spiHandle->Instance==SPI1)
  /* USER CODE BEGIN SPI1_MspInit 0 */
  /* USER CODE END SPI1_MspInit 0 */
    /* SPI1 clock enable */
    __HAL_RCC_SPI1_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    /**SPI1 GPIO Configuration
    PB3     ------> SPI1_SCK
    PB4     ------> SPI1_MISO
    PB5     ------> SPI1_MOSI
    GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_5;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
    GPIO_InitStruct.Pin = GPIO_PIN_4;
    GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
    __HAL_AFIO_REMAP_SPI1_ENABLE();
  /* USER CODE BEGIN SPI1_MspInit 1 */
  /* USER CODE END SPI1_MspInit 1 */
  for (uint16_t x=0; x<254; x++){
	  uint8_t chr = 0x55;
	  HAL_SPI_Transmit(&hspi1, &chr, 1, 1);
	  HAL_Delay(10);
	  HAL_GPIO_WritePin(PORT_LD, PIN_LD, SET);
	  HAL_Delay(1);
	  HAL_GPIO_WritePin(PORT_LD, PIN_LD, RESET);
          HAL_Delay(1);
6 REPLIES 6
You need to enable AFIO clock in RCC for this to work.
MSkor.1
__HAL_AFIO_REMAP_SPI1_ENABLE(); is enable by HAL
Try a simple program, which sets PB5 as a GPIO output and toggle it in program.
(In other words, check if PB5 is properly connected).
MSkor.1
Yes I check this at first time.
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, RESET);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, SET);
works ok (whene SPI1 is disabled)
I also replase MCU to new one.
MSkor.1
Ok
I found out what is causing the problem.
you can't have I2C1 enabled with SPI1 even if I2C1 pins are remapped
any way to bypass this problem?
Probably not in an easy way.
If you use I2C as master, you can try to bit-bang it.
You can consider using a different pin-compatible STM32.
