STM32F103 TIM3 Timebase problem?
‎2013-08-21 07:41 AM
My timebase for TIM3 does seem to obey the laws of timebase calculation! I think I've had this problem before, what am I doing wrong.
TIMCLK = 36MHz TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; /* TIM3 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); /* Time Base configuration */ TIM_TimeBaseStructure.TIM_Prescaler = 36000 - 1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_Period = 10 - 1; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); /* TIM enable counter */ TIM_Cmd(TIM3, ENABLE); /* Enable the Interrupt Request */ TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);And in my ISR: GPIOB->ODR ^= GPIO_Pin_0; TIM_ClearITPendingBit(TIM3, TIM_IT_Update);When I use the above, the pulse width of my trace on PB0 is 5ms. Shouldn't it be 10ms?Also when I use Pre = 36000 and Period of anything greater than 2000, the ISR never fires. I'm trying to get a toggle greater than 1sec.- Mark as New
‎2013-08-21 08:19 AM
According to the Clock Tree for TIM2,3, 4 ''If (APB1 prescaler =1) x1 else x2''.
Likely your clock is 72MHz?- Mark as New
‎2013-08-21 08:27 AM
1 Hz interrupt should be
TIM_TimeBaseStructure.TIM_Prescaler = 36000 - 1; TIM_TimeBaseStructure.TIM_Period = 2000 - 1; Period 4000 - 1 for 0.5 Hz (2 sec) Period 8000 - 1 for 0.25 Hz (4 sec) Period can be up to 65535 for 16-bit timers Be sure to also enable NVIC for TIM interrupt If you don't get an update interrupt, then something else is wrong.Up vote any posts that you find helpful, it shows what's working..
‎2013-08-21 08:38 AM
Verified in debug, PCLK1 = 36MHZ.
I went back to the 3210E demo board to make sure I don't have a hardware problem.Here's what the scope tells me:36000/2000 = 1sec int36000/4000 = nothing36000/1000 = 500ms- Mark as New
‎2013-08-21 08:40 AM
Found the problem, I have some ADC stuff in the ISR that was hanging it up.
Thanks!- Mark as New
‎2013-08-21 08:43 AM
TIM3CLK = PCLK1 * 2, per Clock Tree
36000/4000 = nothing Yes, that would be bizarre. Present a complete example.Up vote any posts that you find helpful, it shows what's working..
