Posted on February 05, 2015 at 14:06 Rcc_ClockConfig( ST_RCC_ClkConfigParams_t *p_stfClkConfig)
EN_RCC_STATUS_t en_lResult = RCC_SUCCESS;
INT32U u32_lHSEStatus = 0;
INT32U u32_lCounter = 0;
INT32U u32_lClkFreq;
u32_lClkFreq = p_stfClkConfig->u8_mFreqSelect;
/* Reset RCC clock to default HSI */
p_stgRccRegs->RCC_CR |= RCC_HSI_ON_MASK;
/* wait for hsi ready */
while( !( p_stgRccRegs->RCC_CR & RCC_HSI_RDY_MASK ));
/* reset cfgr register */
p_stgRccRegs->RCC_CFGR = 0x000000;
/* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
p_stgRccRegs->RCC_CFGR &= (INT32U)0xF8FF0000;
/* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE */
p_stgRccRegs->RCC_CFGR &= (INT32U)0xFF80FFFF;
/* reset HSE_ON,PLL_ON and CSS_ON bits */
p_stgRccRegs->RCC_CR &= (INT32U)0xFEF6FFFF;
/*Reset HSE_BYP bit */
p_stgRccRegs->RCC_CR &= (INT32U)0xFFFBFFFF;
/* Disable all interrupts */
p_stgRccRegs->RCC_CIR = 0x009F0000;;
/* Enable HSE */
p_stgRccRegs->RCC_CR |= RCC_CR_HSE_MASK;
/*wait for HSE ready */
do
u32_lHSEStatus = (INT32U)( p_stgRccRegs->RCC_CR & RCC_CR_HSERDY_MASK);
u32_lCounter = u32_lCounter + 1;
}while( (0 == u32_lHSEStatus)&( u32_lCounter != 0x0500) );
if((p_stgRccRegs->RCC_CR & RCC_CR_HSERDY_MASK) != 0)
u32_lHSEStatus = (INT32U)0x01;
else
u32_lHSEStatus = (INT32U)0x00;
if( p_stfClkConfig->en_mSysClk == RCC_SYSCLKSRC_PLL )
if( 2 == RCC_SYSCLKSRC_PLL)
/* configure PLL */
if( 0x01 == u32_lHSEStatus )
p_stgRccRegs->RCC_CFGR |= (INT32U)(( PLL_HSE_SELECT << 16)| RCC_PLLMUL_3 );
/* SWITCH on main pll */
p_stgRccRegs->RCC_CR |= RCC_CR_PLLON_MASK;
/* wait until pll is ready */
while(( p_stgRccRegs->RCC_CR & RCC_CR_PLLRDY_MASK ) == 0);
/* configure system clock source as PLL */
p_stgRccRegs->RCC_CFGR &= ~( RCC_CFGR_SWS_WRITE_MASK );
p_stgRccRegs->RCC_CFGR |= ( p_stfClkConfig->en_mSysClk & RCC_CFGR_SWS_WRITE_MASK);
/* check the status of sysclock source */
while(!((p_stgRccRegs->RCC_CFGR & RCC_CFGR_SWS_READ_MASK) >> 2) \
== p_stfClkConfig->en_mSysClk);
/* Configure the AHB Clock as per the User Requirement - 72MHZ */
p_stgRccRegs->RCC_CFGR &= ~(RCC_CFGR_HPRE);
/* no prescaler for AHB ->72MHZ */
p_stgRccRegs->RCC_CFGR |= AHBPrescTable[((p_stgRccRegs->RCC_CFGR & RCC_CFGR_HPRE) >> RCC_CFGR_HPRE_OFFSET)];
/* Configure the APB1 bus Frequency by Dividing the AHB Clock ->36MHZ*/
p_stgRccRegs->RCC_CFGR &= ~(RCC_CFGR_PPRE1);
p_stgRccRegs->RCC_CFGR |= (p_stfClkConfig->en_mAPB1ClkDiv << RCC_CFGR_APB1_OFFSET);
/* Configure the APB2 Frequency by Divding the AHB Clock frequency = 72MHZ*/
p_stgRccRegs->RCC_CFGR &= ~(RCC_CFGR_PPRE2);
p_stgRccRegs->RCC_CFGR |= ( p_stfClkConfig->en_mAPB2ClkDiv << RCC_CFGR_APB2_OFFSET);
/* Configouring the High Speed Extenal Oscillator */
while(!(p_stgRccRegs->RCC_CR & RCC_CR_HSERDY_MASK));
return en_lResult;
