stm32f100 Flash Programming strangeness
acihana
Posted on August 06, 2012 at 14:38
Now I'm using a stm32f100c4t6b processor for an application. The proccessor has 16KB memory. I saved my data like that;
#define StartAddr  ((u32)0x08007C00)
#define EndAddr    ((u32)0x08008000)
#define FLASH_PAGE_SIZE    ((u16)0x400)
and I read the data via serial port. No problema.
Strangeness is that EndAddr means 32 KB, my processor has 16KB memory (0x4000) but code is working good. What's my fault? Do you have any idea?
3 REPLIES 3
Posted on August 06, 2012 at 15:47
ST make a finite number of different STM32 die, these are packaged and marked differently depending on the features tested, and how many from each category marketing wants to sell. Realistically they don't make a 16 KB flash part, it probably has 32 or 64KB, the time on the tester can be significantly reduced by not bothering to test it all. General rule, don't use what's not tested, or specified to work. See what the system memory says.
printf(''STM32 %d KB FLASH, %d KB RAM
*((unsigned short *)0x1FFFF7E0),
*((unsigned short *)0x1FFFF7E2));
emalund
Posted on August 06, 2012 at 15:59
you are playing with fire
it is quite common for semiconductor manufactreres to take a part with 64k that in test fail at, say, address 0x8007124 but otherwise works and label it a 16k part
Erik
acihana
Posted on August 06, 2012 at 17:23
Thanks for replies, you're right, according to ''
'' it says 32 KB. But I will not playing with fire :)
