2016-02-24 02:26 AM
we have a simple question. In the devicehttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00090510.pdf
for the stm32f072 page 41 - table 14 colum ''AF2'' describes three-times the function ''TIM2_CH1_ETR''. Is this correct? Normaly the ETR and CH1 functionality are separate. Best regards2016-02-24 02:40 AM
The two funtions are wired together. As ETR is an input and selectable this shouldn't present an issue.
