[STM32F051K8] No SWD connection after some time ...
Options
‎2012-08-10 12:44 AM
Posted on August 10, 2012 at 09:44
I'm working on a custom board around a STM32F051K8. I was playing with it for 2 or 3 days, everything was fine, then without moving it or something, it stopped responding to SWD interface. The previous code is still running in the MCU. The ST Link V2 + ST Link Utilities says not target, JLink manage to stop the core apparently (I have a LED kind of blinking that stops when JLink try to program) but says internal unknown error (the magic one !). At the time it stopped working, I was coding some DMA stuff for PWM. I checked connections, everything is ok. Any hint on what can be wrong ? I know sometimes on STM32F205 when you cannot access the core via JTAG, you can run it in builtin bootloader mode to get access to it, on this board the BOOT0 pin is tied to GND so it would be difficult to do it (I'll try if I can't find another solution). Thomas.
15 REPLIES 15
Options
‎2012-09-21 7:57 AM
Posted on September 21, 2012 at 16:57
Ok it broke under the epoxy ...
Anyway, here is my code right now :int i;
for(i = 0; i<
DMA_BUFFERSIZE
; i++)
m_dmaBuffer[i] = 800 - i*10;
GPIO_InitTypeDef gpio_init;
TIM_TimeBaseInitTypeDef tim_init;
TIM_OCInitTypeDef oc_init;
DMA_InitTypeDef dma_init;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM16, ENABLE);
SYSCFG_DMAChannelRemapConfig(SYSCFG_DMARemap_TIM16, DISABLE); // TIM16 DMA on DMA Channel 3.
gpio_init.GPIO_Mode
GPIO_Mode_AF
gpio_init.GPIO_Pin
GPIO_Pin_8
gpio_init.GPIO_PuPd
GPIO_PuPd_NOPULL
gpio_init.GPIO_Speed
GPIO_Speed_50MHz
gpio_init.GPIO_OType
GPIO_OType_PP
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_2);
GPIO_Init(GPIOB, &gpio_init);
tim_init.TIM_ClockDivision
TIM_CKD_DIV1
tim_init.TIM_CounterMode
TIM_CounterMode_Up
tim_init.TIM_Prescaler
15
tim_init.TIM_Period
0xFFF
tim_init.TIM_RepetitionCounter
1
TIM_TimeBaseInit(TIM16, &tim_init);
oc_init.TIM_OCMode
TIM_OCMode_PWM1
oc_init.TIM_OutputState
TIM_OutputState_Enable
oc_init.TIM_OCPolarity
TIM_OCPolarity_High
oc_init.TIM_Pulse
0xFFF
>>1;
TIM_CtrlPWMOutputs(TIM16, ENABLE);
TIM_ARRPreloadConfig(TIM16, ENABLE);
TIM_OC1PreloadConfig(TIM16, TIM_OCPreload_Enable);
TIM_OC1Init(TIM16, &oc_init);
TIM_DMAConfig(TIM16, TIM_DMABase_ARR, TIM_DMABurstLength_2Transfers);
TIM_DMACmd(TIM16, TIM_DMA_Update, ENABLE);
TIM_Cmd(TIM16, ENABLE);
dma_init.DMA_PeripheralBaseAddr = (unsigned int) (&(TIM16->DMAR));
dma_init.DMA_MemoryBaseAddr = (unsigned int) (m_dmaBuffer);
dma_init.DMA_DIR = DMA_DIR_PeripheralDST;
dma_init.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
dma_init.DMA_MemoryInc = DMA_MemoryInc_Enable;
dma_init.DMA_PeripheralDataSize = DMA_MemoryDataSize_HalfWord;
dma_init.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
dma_init.DMA_Mode = DMA_Mode_Normal;
dma_init.DMA_Priority = DMA_Priority_Low;
dma_init.DMA_M2M = DMA_M2M_Disable;
dma_init.DMA_BufferSize = DMA_BUFFERSIZE;
DMA_Init(DMA1_Channel3, &dma_init);
If I remove the call to DMA_Init it does work and output PWM. As soon as the DMA_Init is in the loop, it stops, even id I don't call the DMA_Cmd to enable it.
Thomas.
Options
‎2012-09-21 10:28 AM
Posted on September 21, 2012 at 19:28
I started again from almost zero and somehow got it to work (there must be some conflict with another part of the code, I'll check later when this is working). Now I'm facing a weird problem ... it seems the values I send to DMA are not correctly aligned or something. Main clock is 48MHz. Timer clock is 3MHz (prescaler = 15) If I set ARR = 250 through DMA, I should have a frequency of 3MHz/250 = 12KHz but the resulting frequency is 46Hz approx, which is about 255 times slower ! The same ratio applies everytime. If I set ARR = 260 then there is no more pulse (CCR1 = 10). I'm transfering 3 unsigned short values at a time to ARR, RCR and CCR1, RCR is always 0. Any idea ? Thomas.Options
‎2012-09-24 11:57 AM
Posted on September 24, 2012 at 20:57
I really need support on this one. I opened a technical support ticket but no reply yet. Is there any better way to get support from ST ? Thomas.Options
‎2012-10-01 3:59 AM
Posted on October 01, 2012 at 12:59
Do you know a way to get support from ST ? I tried anything I found, never had a reply. That is really annoying ... buying thousands of parts and they can't provide ANY technical support for their devices ????? I have a whole project waiting on (probably) a simple reply from a tech support. Thomas.Options
‎2012-10-01 4:00 AM
Posted on October 01, 2012 at 13:00
Do you know a way to get support from ST ? I tried anything I found, never had a reply. That is really annoying ... buying thousands of parts and they can't provide ANY technical support for their devices ????? I have a whole project waiting on (probably) a simple reply from a tech support. Thomas. PS : plus the forum which is complete crap and crashes 75% of the time ...Options
‎2012-10-01 5:06 AM
Posted on October 01, 2012 at 14:06
Usually through the FAE and regional sales guys, both at ST and the distributor level. Practically zero official support on the forum. I'll report the post and see if that gets us anywhere.
- « Previous
- 1
- 2
- Next »
