2014-06-04 09:00 AM
Hello friends,
I have a board using the ''old'' STM32F050K4U6. ST has suddently removed the webpage of this micro .. so I can even not check if ST suggests any replacement or what to do ... So my question is : does anybody knows what should replace the STM32F050K4U6 ? It seems the STM32F031K4U6 is the same, I can't see any difference in the datasheet. Can anyone confirm ? And the last (but not least), ST says ''No availability reported, please contact ourhttp://www.st.com/stonline/contactus/contacts/index.php?type=2
'' ... So what ST does for its customer using a microcontroller that has been produced only 3 years and has been stopped suddently ? Thanks for help. Best regards.2014-06-04 11:15 AM
Mouser says it has 1700 on hand, but the part is EOL
I don't work for ST, but from an industrial perspective it's probably the packaging, either the third-part providing it has stopped doing it, or there is some thermo/mechanical issue that is not economically worth fixing. Or an ability to test. I expect if it's a packaging issue you'll just have to respin the PCB and deal with it. This isn't an era where we can expect 10-20 year product life cycles, low running lines, and fab utilization/redeployment/shutdown can EOL things quicker than anyone can react. If capital manufacture and test equipment fails, it may not be replaced/replaceable. Welcome to the new normal...2014-06-04 11:49 PM
ST has changed naming of some of the STM32. There is a PCN from ST notifying of the change (dated 12.Mar 2014) - Mouser should've implemented it, but I believe it's not easy to follow all the changes:
Previous New
Part Number Part Number STM32F0506DIE1 STM32F0316DIE1 STM32F050C4T6 STM32F031C4T6 STM32F050C4T6TR STM32F031C4T6TR STM32F050C6T6 STM32F031C6T6 STM32F050C6T6TR STM32F031C6T6TR STM32F050C6T7 STM32F031C6T7 STM32F050F4P6 STM32F031F4P6 STM32F050F6P6 STM32F031F6P6 STM32F050F6P7 STM32F031F6P7 STM32F050G4U6 STM32F031G4U6 STM32F050G6U6 STM32F031G6U6 STM32F050K4U6 STM32F031K4U6 STM32F050K6U6 STM32F031K6U6 STM32F313CCT6 STM32F358CCT6 STM32F313RCT6 STM32F358RCT6 STM32F313VCT6 STM32F358VCT6 STM32F383CCT6 STM32F378CCT6 STM32F383RCT6 STM32F378RCT6 STM32F383VCT6 STM32F378VCT62014-06-09 12:02 AM
Thanks Jan,
But unfortunately theSTM32F031K4U6
is not available for purchase .. (at least on stock). Best regards, Vincent.
