STM32F030R8 Time base setup issue
countach
Posted on July 05, 2016 at 12:44
Hi Sir/Madam:
I've encounter a issue about setting Time base on STM32F030R8.
I used TIM14 to be time base.
When I check the 10ms time base in stm32f0xx_it.c.
That was worked normally.
But, I used it to set time flag in main.c
It's worked abnormal.
The waveform isn't regular(not 10ms waveform).
How do I solve it?
Please help me.
Thank you.
Code is as below:
Main.c
extern uint8_t flag;
int main()
    Timer14_Initial();
    GPIO_Initial();
    while (1)
        if(flag == 1)
            flag = 0;
            GPIO_SetBits(GPIOC, GPIO_Pin_8);
        else
            GPIO_ResetBits(GPIOC, GPIO_Pin_8);
stm32f0xx_it.c
uint16_t Capture_Timer14 = 0;
uint8_t flag = 0;
void TIM14_IRQHandler(void)
    static uint8_t CC1_Cnt = 0;
    if (TIM_GetITStatus(TIM14, TIM_IT_CC1) != RESET)
        TIM_ClearITPendingBit(TIM14, TIM_IT_CC1);
        Capture_Timer14 = TIM_GetCapture1(TIM14);
        TIM_SetCompare1(TIM14, Capture_Timer14 + TIM14_CCR_VAL);
        if(++CC1_Cnt >= 10){
            CC1_Cnt = 0;
            flag = 1;
Timer.c
&sharpdefine TIM14_CCR_VAL 1000
void Timer14_Initial(void){
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    uint16_t PrescalerValue = 0;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM14, ENABLE);
    PrescalerValue = (uint16_t)((SystemCoreClock)/1000000)-1;
    /* Time base configuration */
    TIM_TimeBaseStructure.TIM_Period = 65535;
    TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM14, &TIM_TimeBaseStructure);
    TIM_PrescalerConfig(TIM14, PrescalerValue, TIM_PSCReloadMode_Immediate);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = TIM14_CCR_VAL;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OC1Init(TIM14, &TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM14, TIM_OCPreload_Disable);
    TIM_ITConfig(TIM14, TIM_IT_CC1, ENABLE);
    TIM_Cmd(TIM14, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = TIM14_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
#timer
6 REPLIES 6
Posted on July 05, 2016 at 14:29
Not sure exactly what's going on here, but your variable needs to be volatile. I'd recommend toggling the GPIO at each event.
Walid FTITI_O
Senior II
Posted on July 05, 2016 at 15:26
Hi Ben,
Even I don't know why you are waiting 10 times to set the flags in the IRQ_Handler, you should ensure that the declaration ofCCR variable in stm32f0xx_it.c fileas follow:
extern __IO uint16_t TIM14_CCR_VAL;
-Hannibal-
Radosław
Senior II
Posted on July 05, 2016 at 15:44
Hannibal do you think??? TIM14_CCR_VAL is macro.
Only flag variable nedd to be volatile.
But anyway this code is mess.  TIM14_CCR_VAL isn't visiblefor all files where is used.
So this code will never compile succesfull.
Walid FTITI_O
Senior II
Posted on July 05, 2016 at 16:53
Hi , you would change it to a volatile vaiable.
To get more help, I recommend to get a look to ''TIM_TimeBase'' example in
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef0.html
at this path STM32Cube_FW_F0_V1.2.0\Projects\STM32072B_EVAL\Examples\TIM\TIM_TimeBase
You can aslo use
http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-configurators-and-code-generators/stm32cubemx.html
tool to generate correctly your initialization code and start you project development.
-Hannibal-
Posted on July 05, 2016 at 18:44
The OP is clearly not using HAL/Cube. Examples exist within the SPL, and on the forum.
I'd test this by toggling a GPIO, and not having it running under a debugger. I'm not sure why the trace has missing pulses, but I'm not willing to spend my time diagnosing it.
countach
Posted on July 06, 2016 at 10:22
Hi clive1, Hannibal and dembek.radoslaw.001
I make a mistake in TIM14_CCR_VAL.
It should be set volatile not define in a file. (But, IAR don't show any error or warning before change the variable).
After that, it still lose the pulse waveform(I used the example code from en.stsw-stm32140).
Thank you for your reply.
