STM32F030K6T6 - connect under reset.
JKowa
Hello, i have problem with STM32F030K6T6 Mcu. I made my own board with this Mcu. I can connect with it via St-link utility only in Connect under Reset mode. I can earase chip and write new program, but only in this mode.
I also cant connect with mcu while using ​eclipse.
Hardware looks fine with me.
Could you please tell me how to solve this problem
Im using STM32 ​f4 disco board as programmer.
6 REPLIES 6
T J
Lead
Eclipse is not simple to get going.. but it does work. eventually.
Nothing is simple.
I use Visual Studio and GDB ($150)
its very good when the confusion subsides and understanding rolls in... and FAST...
T J
Lead
Nothing is simple.
T J
Lead
Nothing is simple.
waclawek.jan
This is usually caused by the application setting the SWD pins (PA13, PA14) to other than their reset value (ie. MODERx=0b10 for AF, and AFRHx=0).
JKowa
@TJ Im using stm32CubeMx and System Workbench for STM32 and it work great while working with Discovery Boards. I made new project and it start working i do not know why :(
@waclawek.jan It is empty chip, there is no program flashed onto it.
T J
Lead
keep trying different examples,
you will get the hang of it eventually
