STM32CubeMX for SW4STM32 : where is c++ compiler ?
Options
‎2015-06-07 9:37 AM
Posted on June 07, 2015 at 18:37
I've generated a project with cubeMx for System workbench. Now, I add some c++ classes which does not compile because they are compiled by eclipse with gcc and not g++. Can anyone tell me how to fix this ? I can neither find G++ options in project settings. Thanks Julien #c++ #sw4stm32 #cpp
Labels:
SW4STM32
4 REPLIES 4
Options
‎2015-06-08 2:01 AM
Posted on June 08, 2015 at 11:01
You may be more lucky asking this question in the OpenSTM32 (System Workbench)
.Options
‎2015-06-09 7:10 AM
Posted on June 09, 2015 at 16:10
Can't you just set the compiler to g++ (see attached)?
thanks, Paul ________________ Attachments : g__.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzQU&d=%2Fa%2F0X0000000bLl%2FNPQ3vVRZmgOL8GDgp7nBOxwj1YKgvYUWEcsel.Dpebs&asPdf=falseOptions
‎2015-07-17 7:22 PM
Posted on July 18, 2015 at 04:22 I would also like to do this. Have found 2 ways to convert SW4STM32 to C++. After conversion linker brought many errors(undefined reference to `_exit', '_close' and others). Added a syscalls.c file which fixed it. But, now when I try to program the STM32L151RC I get following errors. Can anyone help? ** Programming Finished ** ** Verify Started ** target state: halted target halted due to breakpoint, current mode: Thread xPSR: 0x61000000 pc: 0x2000002e msp: 0x20008000 Error: checksum mismatch - attempting binary compare diff 0 address 0x00008000. Was 0x82 instead of 0xf8 diff 1 address 0x00008001. Was 0x62 instead of 0xb5 diff 2 address 0x00008002. Was 0x98 instead of 0x00 ..... Many more diff x lines ..... ===== Converting Eclipse (SW4STM32 - System Workbench for STM32) to C++ ===== Method 1: Simply add following line to .project file: <nature>org.eclipse.cdt.core.ccnature</nature> Method 2: Select <File><New><Convert to C++ project> in menu bar
Options
‎2015-07-19 6:43 PM
Posted on July 20, 2015 at 03:43
The problem was that after converting to C++ file, the linker file is removed from project properties. Have to go to settings and give in the linker file again.
