stm32cube[fl]*.zip - previous versions
Liviu Ionescu
Posted on February 08, 2015 at 21:52
I'm working on a Git repository with the content of the HAL libraries, where I plan to commit each new release.
Currently only the most recent versions of the libraries are posted on the public site.
Would it be possible for ST to publish the previous releases, in a similar way as for the [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32%20Legacy%20Firmware%20Libraries&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/AllItems.aspx&currentviews=9363]StandardLibrary?
Most urgent for me is to find the v1.2 and v1.0 for the F4 HAL, which is the first I plan to process.
Can someone provide these older releases?
16 REPLIES 16
Posted on February 09, 2015 at 02:20
I have 1.0.0, 1.1.0 and 1.3.0, I need to upload 1.0.0 to my mirror...
Posted on February 09, 2015 at 02:27
https://drive.google.com/file/d/0B7OY5pub_GfIeXAzRnZLRl9ocTg/view?usp=sharing
Liviu Ionescu
Posted on February 09, 2015 at 09:03
got it, thank you.
anyone else having F4 v1.2?
qwer.asdf
Posted on February 10, 2015 at 14:02
Open STM32CubeMX, go to Help -> Install New Libraries
Check the versions you don't have, press the Install button. When it finishes installing, you can find the downloaded ZIP files and extracted files in your User's directory, for examples C:\Users\LeroyJankins\STM32Cube\Repository or C:\Documents and Settings\LeroyJankins\STM32Cube\Repository
Liviu Ionescu
Posted on February 10, 2015 at 15:12
> Open STM32CubeMX,
thank you for your suggestion, I would follow it gladly, but STM32CubeMX does not run on OS X... ;-(
I'll try to use a virtual machine.
Posted on February 10, 2015 at 16:03
That's a neat trick
https://drive.google.com/file/d/0B7OY5pub_GfIa3hFT1MyUnk1R0E/view?usp=sharing
Liviu Ionescu
Posted on February 10, 2015 at 16:37
thank you all, I managed to download all past versions using the CubeMX.
Liviu Ionescu
Posted on February 11, 2015 at 23:09
I posted the past archives on
https://sourceforge.net/projects/micro-os-plus/files/Vendor%20Archives/STM32/
I am still searching the following:
STM32F0xx_StdPeriph_Lib_V1.0.0.zip
STM32F0xx_StdPeriph_Lib_V1.1.0.zip
STM32F0xx_StdPeriph_Lib_V1.3.0.zip
STM32F0xx_StdPeriph_Lib_V1.4.0.zip
STM32F30x_DSP_StdPeriph_Lib_V1.1.0.zip
STM32F30x_DSP_StdPeriph_Lib_V1.2.0.zip
STM32L1xx_StdPeriph_Lib_V1.1.1.zip
STM32L1xx_StdPeriph_Lib_V1.2.0.zip
I would appreciate any links to the above archives.
