2015-02-08 12:52 PM
I'm working on a Git repository with the content of the HAL libraries, where I plan to commit each new release.
Currently only the most recent versions of the libraries are posted on the public site.Would it be possible for ST to publish the previous releases, in a similar way as for the [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32%20Legacy%20Firmware%20Libraries&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/AllItems.aspx¤tviews=9363]StandardLibrary?Most urgent for me is to find the v1.2 and v1.0 for the F4 HAL, which is the first I plan to process.Can someone provide these older releases?2015-02-08 05:20 PM
I have 1.0.0, 1.1.0 and 1.3.0, I need to upload 1.0.0 to my mirror...
2015-02-08 05:27 PM
https://drive.google.com/file/d/0B7OY5pub_GfIeXAzRnZLRl9ocTg/view?usp=sharing
2015-02-09 12:03 AM
got it, thank you.anyone else having F4 v1.2?2015-02-10 05:02 AM
Open STM32CubeMX, go to Help -> Install New Libraries Check the versions you don't have, press the Install button. When it finishes installing, you can find the downloaded ZIP files and extracted files in your User's directory, for examples C:\Users\LeroyJankins\STM32Cube\Repository or C:\Documents and Settings\LeroyJankins\STM32Cube\Repository2015-02-10 06:12 AM
> Open STM32CubeMX,
thank you for your suggestion, I would follow it gladly, but STM32CubeMX does not run on OS X... ;-(I'll try to use a virtual machine.2015-02-10 07:03 AM
That's a neat trick
https://drive.google.com/file/d/0B7OY5pub_GfIa3hFT1MyUnk1R0E/view?usp=sharing
2015-02-10 07:37 AM
thank you all, I managed to download all past versions using the CubeMX.
2015-02-11 02:09 PM
I posted the past archives on
https://sourceforge.net/projects/micro-os-plus/files/Vendor%20Archives/STM32/
.I am still searching the following:STM32F0xx_StdPeriph_Lib_V1.0.0.zipSTM32F0xx_StdPeriph_Lib_V1.1.0.zipSTM32F0xx_StdPeriph_Lib_V1.3.0.zipSTM32F0xx_StdPeriph_Lib_V1.4.0.zipSTM32F30x_DSP_StdPeriph_Lib_V1.1.0.zipSTM32F30x_DSP_StdPeriph_Lib_V1.2.0.zipSTM32L1xx_StdPeriph_Lib_V1.1.1.zipSTM32L1xx_StdPeriph_Lib_V1.2.0.zip
I would appreciate any links to the above archives.2015-02-11 03:30 PM
https://drive.google.com/file/d/0B7OY5pub_GfISWE1ZGdfejU0djg/view?usp=sharing
https://drive.google.com/file/d/0B7OY5pub_GfINXlpeUdZX3Bzc28/view?usp=sharing
https://drive.google.com/file/d/0B7OY5pub_GfIUmlUcklHNU5ra3M/view?usp=sharing
