stm32 rand() problem
lucabe90
Posted on August 24, 2012 at 16:23
hi
i have a problem with the stm32w  mb851a
i would generate a random number. i have try to use the function rand() and I include header file
but when i execute the program it jump at
void __attribute__ ((weak)) Default_Handler()
/* Hang here */
while(1)
why?
this is my include files
#include PLATFORM_HEADER
#include BOARD_HEADER
#include ''hal/hal.h''
#include ''hal/micro/cortexm3/uart.h''
#include ''hal/micro/micro-common.h''
#include ''hal/micro/cortexm3/micro-common.h''
#include ''include/phy-library.h''
#include ''hal/error.h''
#include <stdio.h>
#include <stdlib.h>
#include ''hal/micro/temperature_sensor.h''
#include <time.h>
#include <math.h>
int main()
int a=0;
   a=rand();
7 REPLIES 7
Posted on August 24, 2012 at 17:43
With WHAT compiler/toolchain?
Most likely cause of a Hard Fault is that you have linked a library with ARM 32-bit code, which doesn't run on the Cortex-M3
Use your debugger to look at the faulting instruction, and perhaps use a fault handler that can decode the condition, rather than a while(1) loop. Joseph Yiu has published a book, and web examples of such.
lucabe90
Posted on August 24, 2012 at 19:58
thanks for the answer
i use atollic 3.0.
when i use a debugger i can't see the exectly point when the code jump in the default heandler because when i try to step into the function the execution jump in the default heandler. i search on internet and i think the problem could be that i haven't link the stdlib with the compiler but i haven't idea to resolve that. how can do?
thanks
Luca
Andrew Neil
Evangelist III
Posted on August 24, 2012 at 20:12
''i would generate a random number''
Remember that rand() does not generate true random numbers - just pseudo-random...
Andrew Neil
Evangelist III
Posted on August 24, 2012 at 20:14
Stupid forum insists on hiding text as ''quoted message''
lucabe90
Posted on August 24, 2012 at 20:27
yes i need a pseudo-random number
thanks for the detail
alaa_06
Posted on February 09, 2013 at 04:00
what this problem ???
It appears unrelated to this thread. That BOARD_HEADER isn't resolving to a quoted file name in the preprocessor?
