STM32 controller works using gcc compiler or not
Options
‎2009-12-06 2:51 AM
Posted on December 06, 2009 at 11:51
3 REPLIES 3
Options
‎2011-05-17 4:33 AM
Posted on May 17, 2011 at 13:33
Hi,all!
I am using STM32F103 controller.Presently i am using Keil real view compiler v3.85. But this compiler is supporting up to 32KB of memory. If i am using doing the project with GCC compiler it is not executing. [ This message was edited by: praveen0027 on 05-12-2009 13:38 ]Options
‎2011-05-17 4:33 AM
v3.85. But this compiler is supporting up to 32KB of memory.That's because you are using the free Evaluation version - the compiler actually supports waaaaaaaaaaaaay more than that - but you have to pay for a proper licence!Quote:
What is not executing? Do you mean the compiler itself doesn't run on your PC, or the generated code doesn't run on your target hardware?Options
‎2011-05-17 4:33 AM
praveen0027, the GCC works well with STM32, being used in many many projects.
Which toolchain do you use with GCC? Do you have proper memory map, start-up files, libraries?
