2025-04-24 1:16 PM
Is the internal bootloader on the STM32H723 DO-178 certified? It just dawned on me that the whole line of CPUs might be disqualified for aircraft use because the bootloader code "flies" with the aircraft and all such code must be certified to the level declared by the system (DAL levels A-D). Do you have avionics customers that use these? Can the bootloader be erased?
Mark
