STM32 ADC limited common mode range
for a switched capacitor ADC with differential inputs, I would expect no limits on common mode voltage as long as input voltage is in the GND/VDDA range. However STM32 ADCs only allow a small range of common mode voltage around (Vref- VDDa) /2. In some test circuit with common mode voltages outside that range I got (stable) values several percent off.
- Why has the STM32 ADC this requirements
- Is there characteristic data what happens outside the allowed range?
