STM2F105RCT6 CAN problem
Options
2013-06-11 12:52 AM
Posted on June 11, 2013 at 09:52The original post was too long to process during our migration. Please click on the attachment to read the original post.
1 REPLY 1
Options
2013-06-11 6:49 AM
Posted on June 11, 2013 at 15:49
Make sure you have a short length of twisted-pair wire between the two transceivers, about 10cm, and that you have a 120 ohm termination resistor on both ends of the cable.
Check with a scope that you are seeing data coming out of the transceiver, differential pair has one line hi and the other low. Jack Peacock
