2015-10-16 01:54 AM
I've found that on the ST32F429 DISCO that the library STemWin STemWin522_CM4_OS_GCC.a works and yet the later version STemWin528_CM4_OS_GCC.a does not. Its hangs somewhere after GUI_X_Config(). I have the CRC module enabled.
Also the size difference in these libs, the newer ones is nearly four times the size!Does anyone know what may have changed between versions 522 and 528? Thank you.2015-10-21 06:11 AM
Hi lowit.alan,
Please try to add or verify the value of allocated memory for GUI.Could you precise in which package's version you have found the issue?-Shahrzad-
