ST_Dalislave
SRAM.11
Hi people,
    I just work on a Dali project and trying to learn from the demo library I am getting some error can anyone PLEASE help me how to proceed.
I am trying in STM32G0
I am getting error as EXTI.Instruture undeclared i tried EXTI.Instruct but still its showing error  'NVIC_InitStructure' undeclared
hOW CAN I DECLARE THAT FUNCTIONS
void receive_tick(void)
  // Because of the structure of current amplifier, input has
  // to be negated
  actual_val = get_DALIIN();
  tick_count++;
  // edge detected
  if(actual_val != former_val)
    switch(bit_count)
    case 0:
      if (tick_count > 2)
        tick_count = 0;
        bit_count  = 1; // start bit
      break;
    case 17:      // 1st stop bit
      if(tick_count > 6) // stop bit error, no edge should exist
        flag = ERR;
      break;
    default:      // other bits
      if(tick_count > 6)
        if(bit_count < 9) // store bit in address byte
          address |= (actual_val << (8-bit_count));
        else             // store bit in data byte
          dataByte |= (actual_val << (16-bit_count));
        bit_count++;
        tick_count = 0;
      break;
  }else // voltage level stable
    switch(bit_count)
    case 0:
      if(tick_count==8)  // too long start bit
        flag = ERR;
      break;
    case 17:
      // First stop bit
      if (tick_count==8)
        if (actual_val==0) // wrong level of stop bit
          flag = ERR;
        else
          bit_count++;
          tick_count = 0;
      break;
    case 18:
      // Second stop bit
      if (tick_count==8)
        flag = NO_ACTION;
        //enable EXTI
        EXTI_InitStructure.EXTI_Line = EXTI_LINE_6;
        EXTI_InitStructure.EXTI_Mode = EXTI_MODE_INTERRUPT;
        EXTI_InitStructure.EXTI_Trigger = EXTI_TRIGGER_FALLING;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
        DataReceivedCallback(address,dataByte);
      break;
    default: // normal bits
      if(tick_count==10)
      { // too long delay before edge
        flag = ERR;
      break;
  former_val = actual_val;
  if(flag==ERR)
    flag = NO_ACTION;
    //enable EXTI
    EXTI_InitStructure.EXTI_Mode = 'EXTI_MODE_INTERRUPT';
1 REPLY 1
