sprintf function and Cyrillic
Alex Golubev
I ran into the following problem the sprintf(str, "привет") function; encodes in a two-byte format. Each even character = 208 (dec).
str[0]	char	208 '�?'
str[1]	char	159 '\237'
str[2]	char	209 'Ñ'
str[3]	char	128 '\200'
str[4]	char	208 '�?'
str[5]	char	184 '¸'
str[6]	char	208 '�?'
str[7]	char	178 '²'
str[8]	char	208 '�?'
str[9]	char	181 'µ'
str[10]	char	209 'Ñ'
str[11]	char	130 '\202'
11 REPLIES 11
Pavel A.
Evangelist III
Maybe both source and target charsets for gcc should be specified:
gcc -finput-charset=CP866 -fexec-charset=CP866
Depends on the default with which gcc was built.
I tried also to pretend that both charsets are UTF-8 (though source is CP866) ; it seems to work.
 gcc -finput-charset=utf-8 -fexec-charset=utf-8
0693W000007BZFzQAO.jpgOutput:
$ gcc -finput-charset=UTF-8 -fexec-charset=utf-8 ***.c
$ ./a.out
[0] AF
[1] E0
[2] A8
[3] A2
[4] A5
[5] E2
[6] 00
strlen=6
 As you see the string is correctly encoded in 866, each char one byte.
-- pa
Alex Golubev
How to add cp866 to the debugger?
