Setting Timer to 1ms
santosh
Posted on June 03, 2014 at 17:04
Hi All,
I am using STM32 F0 Discovery board with Raisonance IDE, I am with LED blink using TIM. I want to blink for every 1s but I dont know how to set the timer, Please tell me how the calculation is done for 1s and 1ms. And what should be the value of Prescalar value,TIM_Period n TIM_Prescaler. Right now I have put random values. Please guide me.
PrescalerValue = (uint16_t) (SystemCoreClock  /2400000 );
 /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 1000;
 TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Down;
8 REPLIES 8
Posted on June 03, 2014 at 17:39
It's simple math using factors, the Prescaler and Period are feed with maximal values, where N ticks are represented as 0 to N-1. The Prescaler is 16-bit, the Period may be 16-bit or 32-bit depending on the timer, not sure on F0 options
With a 24 MHz clock, 1 ms = 24000 ticks,
TIM Update = TIM Clock / (X * Y)
Prescaler = X - 1
Period = Y - 1
For 1 ms,
X = 1, Y = 24000 or
X = 24, Y = 1000
For 1 s
X = 24000, Y = 1000 or
X = 2400, Y = 10000 or
X = 800, Y = 30000 or
X = 400, Y = 60000
I'd use the UP count mode, one could also drive an LED directly from a TIM channel
santosh
Posted on June 04, 2014 at 07:29
Hello Clive,
I set the values as per ur suggestion for 1s but the LED does not blink exactly at 1s, so I have attached the file of my project. Mine is 48MHz so I have adjusted as as per that clock. Appreciate your work. Thanks
________________
Attachments :
main.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0za&d=%2Fa%2F0X0000000bgf%2FnPPkmk_nooBoH4t7splw9qhgt9XwgpM2MUGH5QCbztI&asPdf=false
Posted on June 04, 2014 at 13:11
I don't see any interrupt handling code!
You want to use the UPDATE interrupt, not CC1
santosh
Posted on June 04, 2014 at 13:41
Below is my IRQ handler. It is in ''stm32f0xx_it.c''. I replaced CC1 with Update. I can blink the Led for every 1s. But only when
Prescaler= 2000
Period= 24000
And Blinking time differs for other values which u had mentioned for 1s. Why is it so???
void TIM14_IRQHandler(void)
    if (TIM_GetITStatus(TIM14, TIM_IT_Update) != RESET)
        TIM_ClearITPendingBit(TIM14, TIM_IT_Update);
        TimingDelay_Decrement();
Posted on June 04, 2014 at 15:31
Probably because I made the assumption you were using a 24 MHz clocks, and you aren't?
Posted on June 04, 2014 at 15:53
This is how I might present an example, a somewhat blind implementation but should be functional
/* TIM14 1 Hz Toggle STM32F0 sourcer32@gmail.com */
#include ''stm32f0xx.h''
void RCC_Configuration(void)
/* GPIOC Periph clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
/* TIM14 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM14, ENABLE);
void GPIO_Configuration(void)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC, GPIO_Pin_8);
GPIO_ResetBits(GPIOC, GPIO_Pin_9);
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* Enable the TIM14 global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM14_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void TIM_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_TimeBaseStructure.TIM_Prescaler = (uint16_t) (SystemCoreClock / 1000) - 1; // To KHz
TIM_TimeBaseStructure.TIM_Period = 1000 - 1; // To Hz
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM14, &TIM_TimeBaseStructure);
/* TIM Interrupts enable */
TIM_ITConfig(TIM14, TIM_IT_Update, ENABLE);
/* TIM14 enable counter */
TIM_Cmd(TIM14, ENABLE);
/* LED toggling */
GPIOC->ODR ^= GPIO_Pin_8 | GPIO_Pin_9;
int main(void)
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration();
TIM_Configuration();
/* Infinite loop */
while (1);
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf(''Wrong parameters value: file %s on line %d
'', file, line) */
/* Infinite loop */
while (1)
#endif
santosh
Posted on June 05, 2014 at 06:11
Thank you so much Clive, it worked. Now what should I do for setting 1ms in this
I didn't understand the calculation behind this?? Please
Posted on June 05, 2014 at 18:28
TIM_TimeBaseStructure.TIM_Period = 1000 - 1; // To Hz I didn't understand the calculation behind this?? Please
I explained the math earlier, you are dividing a source clock with two factors.   1 ms   TIM_TimeBaseStructure.TIM_Prescaler = 0; // No division  TIM_TimeBaseStructure.TIM_Period = (uint16_t) (SystemCoreClock / 1000) - 1; // Clocks for 1/1000th of a second (millisecond)    Understand that 1 second is 48000000 ticks of a 48 MHz clock, 1 millisecond would be 1/1000th of that, ie 48000   The values programmed into the hardware for comparison are N-1
