Segger SystemView with FreeRTOS
‎2017-09-21 11:50 PM
Has anyone tried using Segger's SystemView on a FreeRTOS project. I am trying to get SystemView working on a FreeRTOS project created using CubeMX.
I am having trouble patching the FreeRTOS files with the patch file provided by Segger.
‎2017-11-10 10:03 AM
Any progress with this?
‎2017-12-12 10:22 AM
I did. Replace your ST-Link Firmware with SEGGER Firmware and follow the instructions in their PDF document
or use a J-Link (EDU) to achieve a better performance when you want to debug parallel.
- Joerg -
‎2017-12-12 11:29 AM
I am using a NUCLEO-H743ZI, and for some reason neither systemview nor jscope could find _SEGGER_RTT automatically, when it was located in DTCM. So i moved it to RAM_D1, and it resolved the issue...
‎2017-12-12 11:58 AM
I use both SystemView and Jscope extensively. Both on a Linux host.
You'll need to match the patch with the version of FreeRTOS. V9 is current and the V9 patch is available as well.
What issues are you having in particular?
I've included my entire FreeRTOS source that has already been patched.
________________ Attachments : FreeRTOS.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyG9&d=%2Fa%2F0X0000000b56%2FEFXyowB0WXdvyEE.qMcI7EUi6g8uV_oAeOHfLPeTzHo&asPdf=false
