-----????_---- ---??as
Sector Codes Can Bootloader
Posted on August 15, 2017 at 18:00
According to AN3154 Datasheet I must write sector code in data field.But I dont know what is sector code and How can i find it for stm32f4 discovery?Just I want to erase sector by sector what I must do?(I know I must write stdid=>0x43 dlc=>? data=?)
    STOne-32
    Posted on August 15, 2017 at 19:21
    Sector code is the number of the sectors , for example if you want to Erase 4 first sectors, you need to send the their numbers : 0 , 1 , 2, 3.  as in our Reference Manual for STM32F405/407 of that discovery RM0090.
    Check also if it is an Erase 0x43  or Extended Erase 0x44 in AN2606/AN3154.
    Cheers,
    STOne-32.
    Posted on August 16, 2017 at 09:47
    I write like this to erase 4 first sectors but not working...
    hcan.pTxMsg->StdId = 0x43;
    hcan.pTxMsg->RTR = CAN_RTR_DATA;
    hcan.pTxMsg->IDE = CAN_ID_STD;
    hcan.pTxMsg->DLC = 4;
    hcan.pTxMsg->Data[0] = 0x00;
    hcan.pTxMsg->Data[1] = 0x01;
    hcan.pTxMsg->Data[2] = 0x02;
    hcan.pTxMsg->Data[3] = 0x03;
    HAL_CAN_Transmit(&hcan, 10);
