SDD1963 LCD Controller with FSMC
gsilva
Posted on March 11, 2013 at 20:21
Does anybody already used sdd1963 lcd controller with STM32 through FSMC?
The used code to configure the FSMC is:
void FSMC_LCD_Init(void)
  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  p;
  p.FSMC_AddressSetupTime = 0x01;
  p.FSMC_AddressHoldTime = 0x01;
  p.FSMC_DataSetupTime = 0x04;
  p.FSMC_BusTurnAroundDuration = 0x00;
  p.FSMC_CLKDivision = 0x00;
  p.FSMC_DataLatency = 0x00;
  p.FSMC_AccessMode = FSMC_AccessMode_A;
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
  /* Enable FSMC Bank1_SRAM Bank */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
My doubt is in the FSMC_MemoryType configuration? I found some examples code in the net and some uses FSMC_MemoryType_SRAM and others FSMC_MemoryType_NOR.
Does anybody can share the FSMC initialization code for this controller or help me, please?
My lcd initialization is
void ini(void)
  lcd_rst();
  LCD_WR_REG(0x0001);
  Delay(500);
  LCD_WR_REG(0x0011);
  Delay(500);
  LCD_WR_REG(0x0029);
  Delay(500);
  LCD_WR_REG(0x00E2);
  Delay(500);
  LCD_WR_Data(0x0021);
  Delay(500);
  LCD_WR_Data(0x0002);
  Delay(500);
  LCD_WR_Data(0x0004);
  Delay(500);
  LCD_WR_REG(0x00E0);
  Delay(500);
  LCD_WR_Data(0x0001);
  Delay(500);
  LCD_WR_REG(0x00E0);
  Delay(500);
  LCD_WR_Data(0x0003);
  Delay(500);
  LCD_WR_REG(0x0001);
  Delay(500);
  LCD_WR_REG(0x00E6);
  Delay(500);
  Delay(500);
  LCD_WR_Data(0x0048);
  Delay(500);
  LCD_WR_Data(0x009E);
  Delay(500);
  LCD_WR_REG(0x00B0);
  Delay(500);
  LCD_WR_Data(0x0028);
  Delay(500);
  LCD_WR_Data(0x0000);
  Delay(500);
  Delay(500);
  LCD_WR_Data(0x003F);
  Delay(500);
  Delay(500);
  LCD_WR_Data(0x00EF);
  Delay(500);
  Delay(500);
  LCD_WR_REG(0x00B4);
  Delay(500);
  Delay(500);
  LCD_WR_Data(0x00B8);
  Delay(500);
  Delay(500);
  LCD_WR_Data(0x0046);
  Delay(500);
  LCD_WR_Data(0x000F);
  Delay(500);
  Delay(500);
  Delay(500);
  LCD_WR_REG(0x00B6);
  Delay(500);
  Delay(500);
  Delay(500);
  Delay(500);
  LCD_WR_Data(0x000B);
  Delay(500);
  LCD_WR_Data(0x0007);
  Delay(500);
  Delay(500);
  Delay(500);
  LCD_WR_REG(0x002A);
  Delay(500);
  Delay(500);
  Delay(500);
  Delay(500);
  Delay(500);
  LCD_WR_REG(0x002B);
  Delay(500);
  Delay(500);
  Delay(500);
  Delay(500);
  Delay(500);
  LCD_WR_REG(0x00F0);
  Delay(500);
  Delay(500);
  LCD_WR_REG(0x003A);
  Delay(500);
  LCD_WR_Data(0x0003)
  Delay(500);
  LCD_WR_REG(0x0013);
  Delay(500);
  LCD_WR_REG(0x0029);
  Delay(500);
Thanks in advance!
Best regards,
Guilherme Amaral
#ssd1963-stm32-fsmc-lcd
4 REPLIES 4
tomstone9
Posted on March 12, 2013 at 21:15
Yes, i am using it.
See:
http://youtu.be/7TZ0zIe6WRo
As soon as i get to the work i will post you a fsmc setup configuration.
tomas239955_stm1_st
Posted on March 13, 2013 at 10:31
So, as I promised before. Here are the init script and SSD driver written by myself and used in posted video.
PS: See the attachment.
PSS: The SSD configuration is:
typedef struct {
uint8_t HFLIP;
uint8_t VFLIP;
uint16_t HRes;
uint16_t VRes;
uint32_t pixel_clock;
uint16_t Htotal_period;
uint16_t Hnon_display;
uint8_t Hsync_pulse;
uint16_t Vtotal_lines;
uint16_t Vnon_display;
uint8_t Vsync_pulse;
uint8_t brightness;
} system_config_t;
const system_config_tsystem_conf= {
0,//HFLIP
1,//VFLIP
320,//HRes
240,//VRes
6400,//pixel_clock
408,//Htotal_period
68,//Hnon_display
30,//Hsync_pulse
262,//Vtotal_lines
18,//Vnon_display
4,//Vsync_pulse
0xA0, //brightness
TK
________________
Attachments :
fsmc.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0eO&d=%2Fa%2F0X0000000bgt%2FtLCVb20nKAFlxERFejCOFg3gZHDd6HQryooiMKBzuXc&asPdf=false
fsmc.h : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0g6&d=%2Fa%2F0X0000000bgv%2Fj_8nLyBjfXUhwXPRrnRxUntLMFN9NFI0EwXEvanCYwk&asPdf=false
SSD.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0fY&d=%2Fa%2F0X0000000bgw%2F_dQ6jU.J7LqUrSjiBx3W6WG.rKKiBuI.Zq3whpIRoIg&asPdf=false
SSD.h : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I10s&d=%2Fa%2F0X0000000bgq%2FFS2hjIL_912ANOi9tlaOn.K1m1PHrQWECpYS9EyobbY&asPdf=false
gsilva
Posted on March 14, 2013 at 16:49
Hi Tomas!
Nice video! Congratulations!
Thanks for the reply
and
consequent
help.
The code will be usefull to I understand where I'm failing.
Best regards,
Guilherme Amaral
NEERAJ GUPTA
Posted on September 15, 2014 at 14:25
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6g8&d=%2Fa%2F0X0000000bt3%2FUbUlW6nZbYaW5mHlV32T1Hqj3D7QKcjr.k4CAnEPYwY&asPdf=false
