RTC isn't updating time in free running mode
‎2024-03-10 9:21 PM - last edited on ‎2024-03-11 12:43 AM by Sarra.S
Hi All,
I am facing problem with RTC in STM32.i have written function in my code where i am updating display function for time every 1 min. But whenever i am trying to see the updated time in free running mode i am unable to see that. But it works fine in debugging mode or at power on or when i program microcontroller.
Please suggest what can be done to resolve this issue? Thanking you in advance.
RTC
‎2024-03-18 2:26 AM - edited ‎2024-03-18 2:30 AM
from HAL lib:
> @note You must call HAL_RTC_GetDate() after HAL_RTC_GetTime() to unlock the values
-- but call date first.... :)
on which cpu ? (Maybe problem with cache...?)
‎2024-03-11 12:51 AM
Hello @Rushali,
This seems to be related to the shadow registers update, to be sure, you can enable the bypass shadow (RTC_CR_BYPADHAD) in your main function, to see if the issue is fixed.
Also, please specify the stm32 product you are using!
Thank you!
‎2024-03-12 3:20 AM
Dear @Sarra.S
I have checked with
HAL_RTCEx_EnableBypassShadow(&hrtc1); by using this command still not able to see the updated time on screen
‎2024-03-15 1:42 AM
Dear All,
Can anybody help me with above problem????????.............
‎2024-03-15 1:57 AM
Hello @Rushali, sorry for the delayed answer
Can please elaborate more on your problem so we can help you!
‎2024-03-18 1:39 AM
I have attached file along with this post for you to get a better idea about the code .
‎2024-03-18 1:40 AM
from HAL lib:
‎2024-03-18 3:00 AM
hey hii @AScha.3
It works fine after calling rtc_get_time first and rtc_get_date later. Thank you.
