rtc calendar application, urgent
lakshmikantha85
Posted on February 11, 2011 at 17:04
2 REPLIES 2
Chris1
Senior III
Posted on May 17, 2011 at 14:24
Assuming your system starts up with the right oscillators and peripheral clocks enabled; to write to the backup registers the following should be sufficient:
 PWR_BackupAccessCmd(ENABLE);            // allow access to Backup Registers
 BKP_WriteBackupRegister(BKP_DR2, 0x0005); // write value 5 to BKP_DR2
[PWR_BackupAccessCmd(ENABLE); is probably equivalent to PWR->CR |= PWR_CR_DBP;].
-Chris
I am storing date in backup registers. BKP2,3,4
Or use a 32-bit time scale like UNIX time. And you wouldn't have to watch for the RTC wrapping every 24 hours.
