Retarget printf() on GCC / IDEaliST?
ccowdery9
Posted on October 16, 2009 at 08:52
12 REPLIES 12
slawcus
Posted on May 17, 2011 at 12:55
Try adding -msoft-float
pramod
Hi slawcus,
Tried -msoft-float already, but it does not work :(
It produces error:
...libc.a uses Hardware FP, whereas Hello.elf uses Software FP.
Once again, I feel that Cortex-M3 does not have hardware FP, but the
gcc library is built using hardware FP option. So can't use this
library for Cortex-M3. Question is how / where to get library built
with sofware FP (suitable for Cortex-M3) ?
Pramod
pramod
Thanks to Jeff, (
http://sourceware.org/ml/newlib/2009/msg00073.html
I found that I am using wrong library version. I changed it to another
version found under sub-directory thumb/thumb2 and then it works fine!
I did not have to ''build'' any new library. It already had many different
versions, built using different options. Only I was using wrong version.
Thank you all for your help.
Pramod
