Question on TIM 1 interrupts
xpp07
I would like to know more about the following interrupts so that I learn when to use them. Where can I find details about them?
TIM1 Break interrupt
TIM1 Update interrupt
TIM1 trigger and commutation interrupt, specially this one
TIM1 Capture Compare interrupt
waclawek.jan
Look at TIMx_SR.TIF and TIMx_SR.COMIF description.
The commutation event is not described clearly; it refers to to CCxE/CCxNE bits when they are preloaded. Essentially, the COM event is generated by TRGI, or by setting TIMx_EGR.COMG. Search for "COM" through the TIM chapter.
