PWM control with DMA and ADC
esiqueira
Posted on June 21, 2012 at 16:58
The original post was too long to process during our migration. Please click on the attachment to read the original post.
Posted on June 21, 2012 at 17:23
Don't know about the general viability of this
But you'll need to fix the Channel# here
 TIM_OC3Init(TIM4, &TIM_OCInitStructure);      // Initializes the TIM Channel 3 according to the parameters specified in the TIM_OCInitStruct
esiqueira
Posted on June 21, 2012 at 20:01
THANKS!!! clive1,,,
%%%%% BELOW THE SOLUTION%%%%%%%%
void TIM_Configuration(void)
 /* Time base configuration */
 TIM_TimeBaseStructure.TIM_Period = 0xFFF;
 TIM_TimeBaseStructure.TIM_Prescaler = 3000;
 TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
 TIM_TimeBaseStructure.TIM_RepetitionCounter = 1;
 TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
 /* PWM1 Mode configuration: Channel1 */
 TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
 TIM_OCInitStructure.TIM_Pulse = 50;
 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
 TIM_ARRPreloadConfig(TIM4, ENABLE);
    // ''connecting'' DMA and TIM3
    TIM_DMACmd(TIM4, TIM_DMA_Update, ENABLE);
 /* TIM3 enable counter */
 TIM_Cmd(TIM4, ENABLE);
     // turning on TIM3 and PWM outputs
    TIM_CtrlPWMOutputs(TIM4, ENABLE);
