Jabalous IbnJabalous
Programming STM32F030C8 using USB-I2C Bridge. Can it be done?
  • June 6, 2017
  • 915 views
Posted on June 06, 2017 at 10:37
Hi
I am planning to use STM32F030C8 in a project, but I want to ask if it's possible to program the chip through I2C. I want to use a controller (might be based on STM32F1 series) to act as a master that will flash the slave controller  (
STM32F030C8)
on another board
. I searched the app notes online and found ST's AN3078 which explains how to do IAP over I2C for STM32F10x microcontrollers in master-slave (US-I2C bridge). Can the same thing be applied to STM32F0 series? Or do they lack this feature?
    martonmiklos
    June 6, 2017
    Posted on June 06, 2017 at 13:16
    According to this:
    http://www.st.com/content/ccc/resource/technical/document/application_note/b9/9b/16/3a/12/1e/40/0c/CD00167594.pdf/files/CD00167594.pdf/jcr:content/translations/en.CD00167594.pdf
    The
    STM32F030C8
    falls into the STM32F05xxx and STM32F030x8  category which only features UART as a bootloader source.
    You can still implement your own I2C  bootloader, but you will still need to program your bootloader first.
    Posted on June 07, 2017 at 10:59
    Could you please recommend me an mcu with similar specs to STM32F030C8 and can be programmed through I2C?
