Problems installing X-CUBE-SPN2 into ST32CubeMX
‎2018-12-18 3:13 AM
I am trying to include in my ST32CubeMX autogenerated project the 2 axis "X-CUBE-SPN2" extension to use the "X-NUCLEO-IHM02A1" board, but the package is not available in the "Additional Software Componenets".
If I downloa the package from official url and try to add using the option "Embedded Software Packages Manager/Local", ST32CubeMX always say that the package is not valid.
https://www.st.com/en/embedded-software/x-cube-spn2.html
What is wrong?, any help would be appreciated.
‎2018-12-18 3:58 AM
This package is not supported by CubeMX yet.
Current supported packages by CubeMX are X-CUBE-BLE1 and X-CUBE-MEMS1.
Laurent
‎2018-12-18 3:58 AM
Laurent
‎2018-12-18 4:13 AM
Hi Laurent,
thanks for the information.
BR,
Francisco
‎2019-09-12 1:53 AM
Hi Laurent,
I have the same issue, I would like to use the SPN2 package for an application created from CubeMX.
Is there any plan to implement SPN2 support for CubeMX?
BR,
Severin
