problem with FreeRTOS and USB
anhhuy0701
Posted on February 26, 2014 at 16:37
hello everyone
today I have a problem but I don't have any solution for that
my problem: with USB per 1(ms) send 1 interrupt to system and if not solve this interrupt, the data will be broken
                     with freeRTOS if the Systick is 1(ms) the overhead will be high and it not good, I want to increase Systick be 10(ms), but if I do like that, that's not compatible with USB.
How can I solve this problem? (I really want to keep the Systick is 10(ms))
(My skill English is not good, if you want more clearly or information, I will provide)
Thank and regard!
11 REPLIES 11
anhhuy0701
Posted on February 27, 2014 at 01:56
hi Jack Peacock
I will make it more clearly
My teacher is sure with usb, 1(ms) it send 1 interrupt (I want to know it right or wrong?)
with usb, 1(ms) it send 1 interrupt for do somethings, and current task is being performing have to stop, but the time for switch context is 10(ms). how can I solve it?
thank!
anhhuy0701
Posted on February 27, 2014 at 02:27
thank Jack Peacock so much, I have solved it
again thank all of you and regards
