2015-02-16 03:59 AM
Hello all,
I am having problem in updating the code to STM32F103ZCT7 using ST link V2.I am getting the error as ''Can not connect to divice; Internal Command Error''I am using three pins SWDIO, SWCLK, NRST. I have cross check the connections using multimeter & all are OK.I have not connected AVcc & AVss pins as well as Vbat pins i.e. they are floating, can this create any problem?Please suggest.Thanking You all. #stm32f103zct72015-02-16 05:23 AM
Analogue supplies are not optional, they control the Power-On-Reset circuit.
2015-02-16 07:20 PM
Thanks Clive. I will power the analog part & will update here soon.
2015-02-18 04:30 AM
Thanks Clive.
Your suggestion worked for me.:-)
